meh03
Jon, which redline ATF would you use for the automatic? Do you like it better than AMSoil?
I can search around on MBWorld if you'd like, and see what they recommend... As far as the 722 transmission is concerned, I would probably stick with the OEM fluid. The manual gearbox had a bit more flexibility, but the auto is a complex animal.
meh03
Also, I'm thinking to do a proper oil change you would need to drop the pan and replace the filter then flush the system on one of the machines. How much fluid would that take?
32Krazy! has done this service on a couple of the AMG/SRT models... Anthony (grip-grip) has as well. I would have to ask one of them, they did a simple drain/refill IIRC...
