Thread: Front disc wear
Old Feb 12, 2014 | 09:00 AM
onehundred80
Default Re: Front disc wear
Originally Posted by Grubnut
Problem solved. The inside edge is raised slightly so that it reaches the wear indicator first. This way you get a warning before the whole pad has worn down. It does mean that bedding them in with caution is more important. Job done
You said wider in the first post and now use the word raised.
