Old Feb 12, 2014 | 05:07 PM
cg80's Avatar
cg80
Thumbs up Re: Ways to beef up your XF?
Originally Posted by Mrmiata
You don't "Have to"... you won't max out the flow till full throttle per say.. kind of like adding K&N filters.. every little bit along the way helps. And that "price" was just a typical average from my research on parts. In real simple terms.. you've got a 3" hole sucking through a 2 3/4" opening.. really would only come in to play at full throttle with the butterfly wide open for that full 3" to suck through.
Greg:
The inference I'm getting from this is: it's an option :yes,if I intend to
"push" the car ,consistently , into a "racing mode", or no, if I just want to have that extra punch from time to time...the latter is where my heads at this time... Thanks again for your knowledgeable input... this forum is the best"car" advice I've ever been associated with... Mucho Kudos to all...Carl
