Thread: 181mm vs. 185mm
Old Feb 22, 2014 | 12:33 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: 181mm vs. 185mm
Originally Posted by tighed1
This was true in my case. Don't know if anyone recalls but I did a sustained high speed run (100-145) over a 20 or so mile distance and had my SC seize up. I was running the same stacked setup that I am running today. Around town I don't have the opportunity (small town) for extended runs. Out of town I know better NOT to do it!
Lesson learned.
So, with this scenario we can assume that they will run a bit lean at the high end, so some fuel delivery modification would be necessary to achieve ideal A/F ratios. Thanks Tighed for helping clear that up, it's too bad you had to learn that the hard way but again, some valuable info for those that follow. It's always tougher to lead.
