Thread: 181mm vs. 185mm
Old Feb 22, 2014 | 01:56 PM
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: 181mm vs. 185mm
Originally Posted by JEFASOLD
So, with this scenario we can assume that they will run a bit lean at the high end, so some fuel delivery modification would be necessary to achieve ideal A/F ratios. Thanks Tighed for helping clear that up, it's too bad you had to learn that the hard way but again, some valuable info for those that follow. It's always tougher to lead.
The SC seizure would not be caused by lean AFR's.
