Old Apr 29, 2006 | 09:06 PM
HDDP's Avatar
HDDP
Default Re: -285 lbs and counting
Originally Posted by woody
It's good to hear that you can now just push forward and develop the car.
Just a note on the AC - you will probably find that the OBD with throw some codes once its all disconnected.
Good Luck!
It's already throwing unusual codes... BAS/ESP light is illuminating (I'll figure that out later) I've gotten most of the passenger side heater fan, filters, casing etc. removed. And the darn passenger side airbag unit must have weighed 20 lbs with the nitrogen bottle...
This is going to take me a good week to remove everything then snug all the wire looms and clean it up. I might have to take it over to my friends shop to get the AC / heater unit out and remove the AC clutch assembly as well as re-routing (plugging) the heating and cooling plumbing and removing the compressor unit.
Nice sketch. Not sure I want to spend $ having a composite hatch made, but may remove the rear glass and install lexan.
Good call on the battery (xfire1) and washer fluid. I might want to convert that to a BEER tap... LOL.
PS: I'm expecting a set of headers in the next few days. Not sure if they will work as they are designed for the C320. Looking under the bonnet I have noticed that our headers have an 02 sensor tapped into them and these do not. I may have to fabricate something after the flange.
