Old Feb 27, 2014 | 08:55 PM
  #57 (permalink)
onehundred80
Default Re: ESP/BAS, ABS and CEL lights
Originally Posted by RED DOG
Happy to hear you finally got it sorted out. Now I have to tackle the same issue that I have on one of my SRT8s. No trouble code found but the ESP / BAS / ABS lights are on. It was an intermittent problem earlier but now seems to be a permanent problem. Guess the easiest fix will be to just have all four wheel speed sensors replaced. Pretty amazing that one can't rely on the trouble code to be accurate indication of the problem . . .
I think that changing everything might get a little expensive and a waste of money. The rears are different from the front. The front has a sensor and a exciter in the hub with the bearing. On the rear the exciter is in the axle and requires replacement of the axle.
My fix cost $500, all around it would have cost at least $1,800.
The garage had a computer that read my error as a rear fault not a front one.
