Old Feb 28, 2014 | 01:38 PM
Number1sith's Avatar
Number1sith
Default
Replacing the RCM relays is not for the faint of heart, or an inexperienced electronics technician with the proper un-soldering equipment,
besides, the only relay that should even NEED replacing is the secondary air pump relay.
All you should be concerned with is cold solder joints ......
What is the original issue that is causing you to eyeball the RCM ?
the secondary air injection issue. I bought enough relays to replace all five and was gonna also pick up some fuses. But I have no experience in soldering. I'll go visit this R/C hobby shop tomorrow by my house to see if they might be able to do it. only issue left till im roaring on the road
