Old Mar 2, 2014 | 10:40 AM
boostmonkey's Avatar
boostmonkey
Default Re: Infinity 6032cf Reference speakers
Originally Posted by hokkabaz
Factory amp/head unit clearly cant support these speakers. When the subwoofers were unplugged, these speakers were working good but since I plugged the subwoofers back, they sound pretty bad once I turn the volume up...(I am not sure about why does it even effect the sound quality since they get the power from different channels)
As some other member said, amp outputs are 22W RMS and these speakers are 60W RMS
The power rating mismatch won't hurt anything. The rms wattge rating on the speakers only tells you the electrical power they can take before thermal damage to the voice coil occurs. A higher rating on the speakers just means you have to worry less about burning them up.
The impedance rating is important. Make sure the amp is designed for the impedance of the speakers you'll be using.
In another car I have a 500w rms sub amp driving a subwoofer only rated for 100w rms. You know what? It sounds great. That amp will drive the subwoofer cleanly right up to the excursion limit (xmax) of the subwoofer, which has an awful sound once you hit it, and will definitely damage the sub if you continued to play it louder than that.
The rule always is: don't turn the music up past the point of audible distortion and you will be fine.
