Re: E test fiasco
Ottawa John
What were the failures for? I'm pretty sure that you can get through with one failure - usually the evap acts up and you won't get it down. Any check engine light on? If not, all you can do is drive it. But on the 3rd failure they'll administer a tail pipe test. I did one last week and it took $70.00 in gas (and a $50.00 lunch with my wife) before we passed. Another one that I know of took two weeks of commuting back and forth to work before the meters reset and got a pass. Just from disconnecting the battery!
So start the Crossfire up and let it idle for a day or so - that might help.
That's good to know, I forget what the failures were but basically the guy said the car did not have enough miles under its belt since the repair. Maybe I should stick $70 in the tank and take you and your wife out to lunch and get to know you. LOL
There has been a lot of upset people with this problem.
Ontario driving cycle to pass the E test.
Chrysler Drive Cycle to pass E test.
