Thread: Horsepower
Old Mar 12, 2014 | 10:12 AM
onehundred80
Default Re: Horsepower
That is why you must set a base line and then use the same dyno and tuner to have an accurate picture of the change made to the engine. Even if the baseline is incorrect, the change is correctly measurable. So a 25% WHP improvement off the same dyno can be applied to what ever Engine spec the manufacturer published. Assuming, of course, IT is accurate you can reasonbly predict your new Crank HP...
OK, so you have a baseline of 143 hp set on the EC dyno, you then modify and finally get a reading of 190 hp. What is the new crank hp?
