Thread: Engine Swap #2
Old Mar 21, 2014 | 09:56 AM
  #144 (permalink)
ChuckNorris's Avatar
ChuckNorris
Default Re: Engine Swap #2
Only issues are a faulty speed sensor and installing a new oil pressure sending unit. I have a new speed sensor to install and will install a new oil pressure sender as well. I have only gone through about 4 tanks of gas in it. It is not geared for highway travel, over 3krpm at 70mph. It will not pass emissions either. There is so much to go over it will be much easier to do in a video. There is also a small trans fluid leak. I'll look at that when I install the speed sensor. It may be that the front seal has not broken in yet or a pan gasket leak.
Before I bought the Pontiac I was planning on changing a few things.
  1. Install a rack and pinion steering to allow room for a true dual exhaust
  2. Swap the TH350 for a 4l80e or T56
  3. Centrifugal Supercharger
  4. SRT 6 springs and brakes
  5. Bigger fuel pump
It would easily be over 600whp with ~14psi boost
