Old Mar 23, 2014 | 01:53 PM
UK-John-SRT-6's Avatar
UK-John-SRT-6
Default Re: Very Loud Continuous Beep
Originally Posted by bigblock427
Hi,
i'm not talking about the sound from the parking sensors, i'm talking about the alarm sound you get when the door is open and the headlights are on.
If the sound ist louder than the sound from the headlights on and door open this is the engine warning sound which comes from the instrument cluster. Normally you get this sound if your'e low on oil pressure. If everything is OK ith your engine and compressor you should check the wiring diagrams and oil pressure sensors and connections to them.
Regards
Markus
Hi Markus
this only happens after driving some time and after using the kick down
IT IS the loudest off all beeps/alarms associated with this car it DOES come from instrument panel IE behind speedo
there are NO warning lights symbols with the beep??????
just has a service oil looks very full ( top of plastic ) and as clean as a whistle
regards
