Old Mar 23, 2014 | 09:10 PM
pizzaguy
Default Re: radiator fan stuck on high
Originally Posted by 04crossfi-er
radiator light is not on.
Ok, so this means the FCM is communicating with the PTCM.
Either the "new' FCM is bad OR the PTCM is bad.
But there is one OTHER possible answer: The PTCM is getting bad data from a sensor and it turning the fan on to try to cool the engine. I am reminded that, somewhere, I read that the sending unit for the gauge is NOT the sensor the PTCM uses to determine engine temperature. If THAT sensor is bad - there you go!
100/80 - am I right about this?
(I'm almost 100% certain I am.) I have an ultragauge on my car and it's "coolant temperature" indication does not quite follow the gauge. I'm thinking the gauge is way too 'damped' or I am seeing the evidence for two sensors.
(You can put a scope probe on the PWM line and look at the length of the pulses and know right away what the PTCM is telling the FCM. Lotsa luck finding a guy at a dealership that has an oscilloscope and knows how to use it.)
