Old Mar 24, 2014 | 10:04 AM
ddonner's Avatar
ddonner
Default Crank, start, die. Crank, start, die. No Crank. The SKREEM!
So, unexpectedly, she went through that sequence. Crank, start, die. Crank, start die. No crank. All of the warning lights were on. I disconnected the battery, she went through the same sequence.
Here is what I learned (thanks to the wisdom contained in the forum. Look for it).
There is a SKREEM Module -- Sentry Key Remote Entry Module. It reads your electronic key. This sequence is what occurs when the SKREEM Module goes bad.
The cost -- surprisingly -- is reasonable. $140 from Chrysler for a rebuilt with a $500 core charge (as of the date of this post). Also available new from "Auto Parts ASAP" (at $800, I think no core charge) and from "Factory OEM Parts of Tampa, Fla" (at $140, I assume with a core charge). They will require your VIN number and milage as part of the ordering process.
The SKREEM is a small electronic module and it is located behind the instrument cluster. It has 2 connectors attaching to 3 connections (the one on the left is a double connector). Its mercedes part number is "170 820 1826" and the book describes it as a door lock module. A chrysler alternitive number which is mentioned in the forum is "50 9954 1 AA". I will attempt to attach a photo, but I am electronically challenged. There are photos available on the forum.
Replacement is simple, once the instrument panel has been removed.
The SKREEM Module has a "learning" sequence to mate your particular key's electronic signature to the Module. Insert Key, turn to accessory, wait for a minute or so, then start. That should have been sufficient education for the Module.
I might also mention the "solder pin connections" issue with the PMC(?) module (see forum). That was my first attempt, but was not my problem. It is a Very Easy thing to do and I believe worthwhile. That module lifts out in 2 minutes, cover comes off in another 2 minutes, careful inspection of the 3 solder joints at the bottom right for fracturing of the solder takes another 2 minutes (I found 1 fracture), re-soldering takes another 3 or 4 minutes, then reassemble. A quick and pleasing preventative maintenance job.
Don
