Crank, start, die. Crank, start, die. No Crank. The SKREEM!
Old Jun 4, 2023 | 04:59 PM
karbun's Avatar
Default Re: Crank, start, die. Crank, start, die. No Crank. The SKREEM!
Interesting. Thanks, I hadn't seen that thread with the grounding mod, and if there was something preventative that could keep me from having to send the unit away for repair that would be great. I drive my car every day. I do keep the battery fresh because the car hasn't done well with an aging battery, but I will check those fuses and potential battery-related vulnerabilities.
And thanks too for all your work and help in the forum more generally. This forum has let me keep my crossfire much longer than I would have been able to if I was having to go through a nightmare with a mechanic who had never seen the car before every time something went wrong.
Kara
Old Jun 5, 2023 | 01:21 PM
Deepsea21's Avatar
A few months ago I had my SKREEM re-programmed when I got the 3 tries and you're out as well. Put it all back together and was working fine. My wife uses it as a daily driver and 1 day she got the 3-strikes issue again (after the fix was done). I too pulled the battery cable, reconnected and it started right up. Haven't had the problem present again. One thing that came to mind (and I told her to stop doing) is she liked to quickly flip the key from "off" all the way to "start" position and then let it go while the car starter engages and car eventually a second later. I told her to stop doing that! Told her to turn the key from "off" to "on" and wait a second, look at dash lights and then on "start". I think her little quick snaps of the key moved it from "off to "start" so fast the SKREEM didn't have a chance to read the chip in the key. This is just a guess as I assume the SKREEM reads the key chip when it reaches the "on" position and power is sent to everything. Since she's slowed down and stopped that key flipping nonsense the car has been starting without any further issues.
Anthonymichael91090
Jun 26, 2022 07:11 PM
pcxldigger
18
Jul 22, 2021 07:37 AM
pv2haisch
33
Apr 24, 2020 11:27 AM
Rpaczan
Jul 26, 2018 09:20 PM
stanced E46
Oct 11, 2014 01:34 PM
