Thread: '04 crossfire
Old Mar 25, 2014 | 06:54 PM
hiflyer's Avatar
hiflyer
Default
[QUOTE=pizzaguy;788251]Just looked at your pictures, it would appear that you used enough heat (and too little heat, not too little solder - is usually where people fail at soldering).
But remember that Tightd1 will swap your RCM for a repaired one for a small, small charge. It CAN be the contacts on the engine control relay (I'd have to check, I think that is the middle relay) but it is usually the solder land(s).[/QUOTE I put a brand new RCM in today and same thing PizzaGuy, it started a couple different times not at first and I drove it once, it ran fine but came home turned it off and same ole issues, lights up but don't crank over! Now I have a new starter and RCM and still have no clue!
