Old Apr 7, 2014 | 05:51 PM
onehundred80
Default Re: problema cierre llave
Originally Posted by MAGNATUDE
(translation)
Key Lock Problem
Hello, I'm starting a new post, since there's another post similar in title and theme. Thank you already if this has been this solved.
The problem now is the following;
The central remote locking system works perfectly, but if I want to lock the car with the key manually, it only locks the driver-side door. The rear liftgate and the passenger-side door stays open.
Anyone experienced this in the past? What is the ruling?
There is a electrical switch in the lock mechanism on the drivers door. Yours is not working, does it unlock all the doors? If it does then it is half working.
Of course it could be a problem with the pump itself that shows up only in this situation.
