Old Apr 10, 2014 | 06:59 PM
onehundred80
Default Re: Need an exorcist
Originally Posted by Mrblue 2250
The new batterys in the fob and car did nothing to help the problem. This first came up a few weeks ago. Was raining and the alarm went off for no reason. I was able to shut it off with key fob but noticed the interior light stayed on. Then the fob stopped opening the doors and hatch. All I have done so far is replaced the batterys in fob and car. When I hit the buttons on the fob the lights flash. My new problem is the running ligths are on and will not turn off. So have disconnected the battery to save it from running down. The key fob still does not open anything. I am not sure what esle can add to this and do appreciate any and all help thanks guys
I'd guess you have water in the trunk and it has damaged the pump/security module under the foam on the passenger side in the trunk. Take the panels out, the foam out and look at the pump. You may be able to see water down the side of the foam, if so pull the plugs out on the underside of the trunk on that side. Water may run out, if it does you should dry the pump out. and look at this how to.
