Old Apr 11, 2014 | 10:13 AM
onehundred80
Default Re: Grommet for passenger side wiper
No. Apparently the supplier either had incorrect measurements or just simply screwed it up.
Seems the decision was made ( no doubt for cost reasons ) to just use them and not install the DS grommet.
You will have to mark a circle around the wiper shaft, then remove the cowl and Dremel it out.
Dremel? An X-ACTO knife works just fine, it is just plastic.
Originally Posted by mongoose57
Thanks you two, as allways solid info can be had on this site. Just wondering guys was there ever a grommet around the passenger side wiper shaft?
Cheers
Mongoose57
On my car the grommet (isolator) was missing from the drivers side. The hole was out of alignment, so they left it off, I recut the hole and fitted the isolator.
