Grommet for passenger side wiper
Old Apr 10, 2014 | 09:45 PM
Mongoose57's Avatar
Default Grommet for passenger side wiper
Hi all! Question is there suppose to be a grommet for the hole that the the wiper shaft protrudes through ( the plastic cowl shield ) also was there suppose to be plastic caps on the nuts holding the wiper arms to the shafts.
Thanks
Mongoose57
Old Apr 10, 2014 | 10:18 PM
Default Re: Grommet for passenger side wiper
Thanks
Mongoose57
Rob sells the plastic caps:
Wiper Arm Nut Caps
Old Apr 10, 2014 | 10:35 PM
Thanks
Mongoose57
Cheaper to get the cap and grommet (isolator) from your local Chrysler dealer.
Isolator part number and install.
05101489AA, CAP, C$5.10
05101283AA, Isolator, C$7.00
Old Apr 10, 2014 | 11:30 PM
Mongoose57's Avatar
Thanks you two, as allways solid info can be had on this site. Just wondering guys was there ever a grommet around the passenger side wiper shaft?
Cheers
Mongoose57
Old Apr 11, 2014 | 08:55 AM
No. Apparently the supplier either had incorrect measurements or just simply screwed it up.
Seems the decision was made ( no doubt for cost reasons ) to just use them and not install the DS grommet.
You will have to mark a circle around the wiper shaft, then remove the cowl and Dremel it out.
Old Apr 11, 2014 | 09:29 AM
Indelibility's Avatar
I like to leave my nuts uncapped.
Old Apr 11, 2014 | 09:50 AM
STEPHENJXN's Avatar
...Nuts Uncapped. Hilarious!
Old Apr 11, 2014 | 10:13 AM
Dremel? An X-ACTO knife works just fine, it is just plastic.
Cheers
Mongoose57
On my car the grommet (isolator) was missing from the drivers side. The hole was out of alignment, so they left it off, I recut the hole and fitted the isolator.
Old Apr 11, 2014 | 10:22 PM
Mongoose57's Avatar
Well I have no problem leaving my nuts exposed when the car is in the garage, but I think it only proper to have your nuts covered up when one is out in public I do think even it was a very minor screw up! I will go ahead and install the ps grommet along with the nut covers. I was looking at the needwings site and could not see the aluminum bolts that hold down the little egr rocker cover.
Is every one just using stainless hardware , I plan on using studs if I can find the right bolt and die.
Cheers
Mongoose57
Old Apr 12, 2014 | 07:07 AM
West Peterson's Avatar
The nut caps may be available from a windshield supplier, too. One of mine was missing when I had my windshield replaced, and they put one on for free.
55chevy
Jul 22, 2024 02:31 PM
Mike OD
Sep 23, 2016 07:00 AM
westonrose
U.K.
Sep 16, 2015 02:22 PM
Posimoto
Sep 13, 2015 06:13 PM
williammt
Sep 6, 2015 11:23 AM
