Re: 15 weeks problem shooting and no repair
This is for 05roadsterguy
So since your not real good at answering the questions posed I would like to hear about this short.
1) did the car run fine before you took the old head unit out? Yes it did –((
2) did you have to cut wires to make the new one fit? No – made a connector to mate with the existing
3) after installing the new Head unit did it power up? Yes and I was dressing up and tiring into the AMP – and stilled worked
4) after installing the new head unit did the car start and drive? Yes
5) How many times? Several times
6) When and how did you learn you had a short in the system? When I was dressing up a loose wire and it sparked against the head of the new radio- and it wouldn’t start
7) which fuse did you change when the head unit didn't work?- None couldn’t find a blown one
