Old Apr 15, 2014 | 10:05 AM
  #44 (permalink)
onehundred80
Default Re: Relay Replacement In RCM
Originally Posted by rvanders37
i think the reason that relay #5 burns up the contact points is because it draws much more current than the other relays. just look at that huge orange fuse for relay #5. the replacement relay AZ970E-1A-12D contacts are rated for 40 amps so we should be good to go with that part installed. and no more code P0410 !
That part has the same specs as the OEM relay. All the relays in the RCM are the same.
