Air conditioning only works when its ready, not when needed!
Apr 19, 2014 | 09:53 PM
permalink
JEFASOLD
Aug 2012
1,709
Re: Air conditioning only works when its ready, not when needed!
Quote:
Red ragtop
Is there anyone else that this happens to and is there a diy repair? Thanks in advance for any help!
As I understand it, there is a hose that runs behind the battery( it needs to be removed to check it) along the firewall that seems to be affected by bat acid, etc. If it's bad( hole) then the mixing doors do not work properly, affecting the AC operation. The fix is cutting the bad section out and using a plastic connector in that area.
JEFASOLD
View Public Profile
Send a private message to JEFASOLD
Find all posts by JEFASOLD
