Air conditioning only works when its ready, not when needed!
Old Apr 19, 2014 | 09:45 PM
Red ragtop's Avatar
Default Air conditioning only works when its ready, not when needed!
Is there anyone else that this happens to and is there a diy repair? Thanks in advance for any help!
Old Apr 19, 2014 | 09:53 PM
JEFASOLD's Avatar
Default Re: Air conditioning only works when its ready, not when needed!
As I understand it, there is a hose that runs behind the battery( it needs to be removed to check it) along the firewall that seems to be affected by bat acid, etc. If it's bad( hole) then the mixing doors do not work properly, affecting the AC operation. The fix is cutting the bad section out and using a plastic connector in that area.
Old Apr 19, 2014 | 10:00 PM
Red ragtop's Avatar
Default
Thanks, I will look at that tomorrow!
Old Apr 20, 2014 | 08:39 AM
Regarding the A/C, I decided yesterday to check my pressures before the REAL heat gets here.
I have NEVER seen a car where you have to remove the grille to access a connector !!!
( FWIW, at 70 F I had 30-35 low and 100-180 high with fan on high, full cold on both dials and recirc engaged. )
I also noticed that the radiator fan was NOT on at all times, it came on intermittently. I had read that it is always on when the A/C is on.
Old Apr 20, 2014 | 11:46 AM
I suppose we could read all sorts of clues to the problem into this statement, but which ones would be correct, if any. Please explain, it may mean something to you but ....
Frankenmerc
20
Dec 13, 2025 11:51 PM
rayth
41
Jul 31, 2019 04:02 PM
RED DOG
Jun 29, 2015 01:20 PM
Jacksung
Jun 23, 2015 04:28 PM
glennnn
Dec 17, 2003 10:12 PM
