Old Apr 20, 2014 | 03:17 PM
  #56 (permalink)
HOT FIYA's Avatar
HOT FIYA
Default Re: New guy from Northern VA!
Originally Posted by velociabstract
My front fenders were rolled by me. They were pulled by Costco when they couldn't get the lift under the front jack pads. Bstards! I can fit a 255 on the front with the roll and 30 offset. My rear track setup is 18x10 with a 25 offset and I have 275's mounted. No roll, 7mm room to the outside. No room to the inside. A 19x10 will fit easily. The problem is the tire at the inner fender well if lowered and wider. I can look for a picture of the front if helpful.
Les
Thanks for the info! Have you ever visited www.willtheyfit.com? I have been part of the "aggressive fitment" crazy long before it blew up and became a mainstream thing and that website has always helped me along the way.
My setup (with spacers) will end up being:
18x8.5 +19 with a 225/40/18 up front and a 19x10 +10 with a 255/40/19 in the rear. Little bit lower offset than your setup but also a little bit less meat (or as I like to call it a "baby stretch").
And I already have that rubbing issue under full lock. Not really a concern......my Miata's rubbing issues were far more extreme.....lol. If it's worsens with the new wheel setup I have a nice rubber mallet that can persuade it to work.
