Old Apr 22, 2014 | 11:19 PM
  #45 (permalink)
DREMB1G's Avatar
DREMB1G
Default Re: Relay Replacement In RCM
After hours of reading I'm afraid I still need to reach out to the Forum for help on my No Start issue. Last fall I put the key in my ignition after purchasing a brand new battery and could hear the starter engage the flywheel for a split second. Repeated attempts to start resulted in the same. The engine did NOT turn over. I pulled the RCM (as pictured above, thanks 180), cleaned the contacts on the start relay, and popped the assembly back into the box. The car fired right up and was great for about a month of use. Last week the same issue came back. I went ahead and ordered a few new relay units to re-solder into the board thinking the unit had burnt up. All fuses check good. The relays all look great. I re-soldered all relays to be safe. Installed the unit and the problem persists as if I had done nothing. I don't believe it is a CPS issue because the engine will not turn over. Is there anything I may be missing here? Please help
