Old May 2, 2014 | 01:22 PM
DTMenace's Avatar
DTMenace
Default Re: Cant get over 100/120??
Originally Posted by SouthernBronco
Ok i need some ideas. Ive spoken with philip bee but im going to a dealership maybe they can tell me but i wanted to ask yall. So heres the deal. Car runs 100% fine no problems. And today i see a nice open road so i punch it and fly all the way to 100 and accel. Stops dead like it goverened or somethin. And i smell this like cooked
Smell not burnt just cooked. So i stop and start from 0 and i shift by hand 0-6000 rpm 1,2,3,4 and then drive and it gets around 4k and 120 mph and just stops again like it goverend. It crawls to 124 then just declines itself even though im in the pedal. So i have checked the oil the fuel pump the coolant all is good pulleys are stock? Any ideas???? I cant even cruise i can cruise into 116-118 and then it stops itself and wont go any more??????
SouthernBronco
Sounds like the beginning of the IC pump failure at the upper end of the RPM range. It will probably start happening at lower RPM soon. The supercharger is shutting down and going into limp mode as a fail safe mode, otherwise the heat will cook the supercharger. The replacement of the IC Pump is about $125.00 + installation charges if you don't do it yourself.
Use the search button and look up IC Pump failures.....
Dennis
DTMenace
