Old May 3, 2014 | 10:17 AM
onehundred80
Default Re: I can't figure it out
Originally Posted by FP
I had DJ rebuild the RCM. It was an exchange, so I don't have the original . It might just be a bad rebuild. Like I said the Cam and crank sensors were replaced after the car stalled while driving. This and the battery were replaced to address this issue. I do think the RCM is defective at this point.
So you replaced the RCM and then the battery and sensors when you had problems. You had no problems before replacing the RCM I take it?
Did you replace the battery before the RCM? If so it may be a bad battery. The exact order of part changes could be important in finding the problem.
