I can't figure it out
May 3, 2014 | 11:53 AM
21
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: I can't figure it out
Quote:
Yes, I agree the draining puzzles me. It only happens when the failure to start occurs, and I let it sit for a while. Once the battery is recharged it starts with no problem. This tells me that something gets reset after the battery discharges.
I am wondering if the relay for the fuel pump has stuck, when you turn the ignition key do you hear the fuel pump stop after a while, say 5 seconds at the most?
I see power going to the relay from a splice which is hot all the time. If the relay was stuck then it would keep drawing power. If not that relay some other relay could be stuck.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
