onehundred80
I am wondering if the relay for the fuel pump has stuck, when you turn the ignition key do you hear the fuel pump stop after a while, say 5 seconds at the most?
I see power going to the relay from a splice which is hot all the time. If the relay was stuck then it would keep drawing power. If not that relay some other relay could be stuck.
That would not explain the engine not turning over.
