Old May 5, 2014 | 08:02 PM
onehundred80
Default Re: Cant get over 100/120??
Originally Posted by oledoc2u
Fuel.........supercharger will cause it to fall on its nose. But, I think you have a fuel problem. Supercharger pump failure will cause it to buck as well, kicking in and out. You stated it just falls off. If it is fine when cold, but does this when it gets to temp, then the pump may be the cause. If it runs strong up to 120 and falls on it's nose, then I would say a fuel pump, or fuel restriction problem.
I too do not think it is the pump, if it was it would fail at lower speeds when the car was hot. I am sure you do go at lower speeds, I cannot see you doing over 100 mph all the time.
