Old May 7, 2014 | 11:39 PM
  #675 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Caleb
Hi, im in serious need of help... I just did all of the steps and after i removed the spring and pin, the locking pin will not press down and the key will not turn in the lock cylinder. Any suggestions?
I am not sure what stage you are at, do you have the lock cylinder and housing apart? Or are they together?
The lock cylinder should not be put in until the housing is back in place and clamped down.
