Re: SRT6 Fuel Pressure setting with AEM Pressure Regulator???
meh03
I'm running a 65mm pulley, single CAI, and about to install NW Manis and a SL55 pump. Low Texas elevation. I was going to replace the stock filter with a new one while installing the pump. Now I'm wondering if I might need to go with the un-regulated filter and separate regulator. Not stacked, but I'm thinking I may be borderline.
For the 65, history would say you are fine but if you ever go smaller or stacked you'll need more fuel. Its a whole lot easier to do it all at once than going back and doing it again. Then you can dial in the pressure as well.
