Old May 10, 2014 | 12:33 PM
onehundred80
Default Re: ESP pressure sensor 1
Originally Posted by meaty62
Hi all
Have the dreaded esp/bas light on, intermittently, have had the codes read with the result C1141 pressure sensor current - 008 + zero point and offset of stored component B34/1 (ESP pressure sensor 1)
anybody out there any idea? have renewed brake pedal switch. Car runs ok when light is on, seems less likely to illuminate when started with foot on the brake pedal.
would help if I knew where esp pressure switch 1 is located
never posted before hope this is correct etiquette
Thanks
Intermittent could mean a bad electrical contact, pull connectors apart and see if they are clean.
There are two pressure sensors on the master cylinder. Look at them.
Look at the Service Manual (click). Down load it for future reference.
