lildaddym
I wasn't aware of this, but I saw some dried rust on my door sill and looked. Sure enough, had some rust bubbles on the driver's side door! Gotta get underway. I can't seem to make heads or tails on something, though: Should I clean the rust and paint off before sealing it? Should I take the door panel off to see if there is any inside the door?
The rust problem seems to be out in the open where you can see it after pulling out the rubber seal, as in Andrews photos at the beginning of this thread. . If you follow his procedure using Por 15, or Por Patch, you should be good to go.
I have a good friend who restores old cars for a living, and he swears by Por 15 products.
Good Luck
