Old May 12, 2014 | 06:59 PM
onehundred80
Default Re: help installing karman pulley
Originally Posted by austinbarrylee
with the bolt tight the pulley can move in and out about 3/16 of an inch. it appears to need a spacer between the washer and the pulley bearing to hold it back
The Karmann pulley should come with a 5mm (.197") spacer as the bearing is 5mm shorter.
