Old May 13, 2014 | 09:03 PM
sk8erjosh09's Avatar
sk8erjosh09
Default
Jim you have little to no room in your engine bay as it is. Even with moving the firewall back where are you going to put 4 more cylinders?
Wouldn't even need to move the firewall. There's a driveshaft I have in mind that'll let the trans sit further back, bringing the motor back. Then the radiator forward an inch with a 1" wide electric fan. Done. You gotta remember the bore is tiny, even in the 65... If that's not enough, you can relocate the radiator support and move the radiator, ac condenser and all that, even farther forward...
