V12 twin turbo in a tiny SLK - check it out!
Old May 12, 2014 | 08:55 PM
grip grip's Avatar
Default V12 twin turbo in a tiny SLK - check it out!
That's right, 750hp, 900 lb-ft of torque in the Crossfire's cousin. Now who's going to fit one in a Crossfire????
Josh, Rudy, are you reading this?????
Just finished...World's Only SLK65 AMG V12 BiTurbo - MBWorld.org Forums
Old May 12, 2014 | 09:06 PM
Adrian_X's Avatar
Default Re: V12 twin turbo in a tiny SLK - check it out!
Sweet jesus, just holy hell!
Old May 12, 2014 | 09:13 PM
velociabstract's Avatar
Paging Jim ……. I love it!
Les
Old May 12, 2014 | 09:21 PM
grip grip's Avatar
Jim's been telling me it's in his head, but will he and Rudy pull it off?? Got me. I tell you one thing, my CL (with said engine) doesn't want any of that ****!
Old May 12, 2014 | 09:28 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
LMAO.
Up to this point you were afraid of nothing.
Old May 13, 2014 | 12:00 AM
Speedy4x4's Avatar
Default
WOW big grats to them. Puts "shoehorn" to a new definition.
Old May 13, 2014 | 01:45 AM
RED DOG's Avatar
That is simply I N C R E D I B L E ! !
Old May 13, 2014 | 02:06 PM
boostmonkey's Avatar
holy sh**!!!!!
Old May 13, 2014 | 02:12 PM
grip grip's Avatar
LMAO.
My car is quick, that SLK is brutal!
Old May 13, 2014 | 02:15 PM
MoparFreak69's Avatar
Quick, someone figure out how to stuff one in a Crossfire!
#shutupandtakemymoney
Old May 13, 2014 | 04:18 PM
sk8erjosh09's Avatar
Easy. You got the money?
Since my goal is the 600 motor in the 55 I've been researching the hell out of the swap concerns of mine and they'll fit, and some of the routing for certain things is a ton easier... Exhaust being the biggest since you don't have to make or create manifolds, you just buy some tube, get it bent, and weld it in place lol. The intercoolers are integrated so you don't even have to worry about mounts, brackets, extreme plumbing or anything... The size scares me a bit, but you can easily push the radiator forward another inch and you're good. Honestly if the suckers werent so damn heavy I would just go that route in the crossie, but the 55K motor will leave me some decent balance. The ECU work? C'mon guys, it shouldn't even be a question at this point lol.
I will point out however that the mentioned SLK ECU work was cake... The E-V12tt ECU work will be done for my car in 30 minutes. I actually wrote out why but then realized that I might need to leave the market open lol. For the Crossfire, it'd be more difficult since we're on the older electronics but definitely no where near as hard as the NA V8 manual ECU retrofit and reconstruction.
Old May 13, 2014 | 06:14 PM
maybe next.
Old May 13, 2014 | 06:43 PM
Abaton6's Avatar
OMG! If I had that thing, I'd be dead or in jail inside of a week.
Old May 13, 2014 | 06:55 PM
Originally Posted by amx1397
maybe next.
Rudy and I have talked about it in your car, I can't wait for that rocketship if you end up doing it!
Old May 13, 2014 | 08:04 PM
Thirteendog's Avatar
8 cylinders is really tight in a Crossfire. There isn't enough room to fit 4 more without extending the front. Even if you did shoehorn one in you'd have cooling issues.
Old May 13, 2014 | 08:48 PM
fire wall could be moved you know,, the problem is all the computers and wiring, that could be solved with a little extra thinking,,, like three heads together instead of one. jim
Old May 13, 2014 | 08:53 PM
Jim you have little to no room in your engine bay as it is. Even with moving the firewall back where are you going to put 4 more cylinders?
Old May 13, 2014 | 09:03 PM
Default
Wouldn't even need to move the firewall. There's a driveshaft I have in mind that'll let the trans sit further back, bringing the motor back. Then the radiator forward an inch with a 1" wide electric fan. Done. You gotta remember the bore is tiny, even in the 65... If that's not enough, you can relocate the radiator support and move the radiator, ac condenser and all that, even farther forward...
Old May 13, 2014 | 09:19 PM
don't know right now, but if it can be done, I would like to do it,, we do have some mods to do to mine next year, that could make it faster,, my request is i want it streetable and reliable,, just so you know we are building another supercharged crossfire, eng is in and runs, just going slow for now,,and yes Rudy is involved in the project. jim
already moved the radiator forward 3"and down 3",, don't forget our streets are from 110 to 130 degrees almost every day
Old May 14, 2014 | 03:02 PM
You moved the radiator THAT far and you still have cooling issues??? You could fit the stock fan back on with it that far back LMAO. That's cool that he built another one. I know I can't wait to have mine done. It seems like wayyy too much after driving the E55 but it'll be fun as hell. The TTV12 is too much for the crossfire IMHO but if someone crazy enough wants to do it I'm sure Rudy will get it done, if he needs help then I'm sure he'll call lol. We've kicked the idea over briefly a couple times but nothing in depth yet, just that we both know we could do it.
