Old May 15, 2014 | 02:17 PM
Speedy4x4's Avatar
Speedy4x4
Default
Originally Posted by velociabstract
You may want to get some custom made wheels. After you buy the wrong wheels, rebore the hubs, buy spacers, hub rings, lugs etc. you'll have real expensive wheels.
Les
Custom rims $1000 and up.
Tsw monaco
18x8.5 5x112 et 37mm front (+ 5mm spacer)
19x10.5 5x114 27mm rear (get a 5mm spacer)
Leave front alone. Will not cost much to have a "machine shop" drill 5x114 in rear rotors and drill and tap 5x114 in hub. So rear hub and rotors will have 5x112 and 5x114 drilled and taped. Wheels have 73 bore so the 5mm spacer on back to have the hub adapter.
What would be the problem with that???
