Old May 16, 2014 | 08:33 AM
onehundred80
Default Re: Cant get over 100/120??
Originally Posted by SouthernBronco
Ok so an update and praying its the pump. It does do it al low speeds to ill pounce at 40-60 and it feels worse than a pruis it just doesnt even want to accelerate. Today this happened and i parked it. I went 0-40 and what i think was second gear it wouldnt shift anymore like at all just high RPMS. I tried slapping and slowing down and stopping and it still wouldnt change when i slapped it stayed in D, i stopped shut it off parked it turned it on and it lemme go so i went home and parked. Still thinking its the IC PUMP going into limp mode to keep me in 2nd
If you mean it does it at low speeds, then stays in second gear then I would say you have problems with the solenoid electrical plate in the transmission. When there are troubles here the tranny goes into limp mode.
Valve, solenoid, speed sensor, etc problems cause this.
Have you had the engine fault codes read? If not do it. Why waste time looking for a problem that good always have been recorded.
Resetting any system is a waste of time, that just fine tunes what is already working, they solve no hard problems.
