Old May 18, 2014 | 09:59 AM
onehundred80
Default Re: Crossfire Wont start or turn over after flood
Originally Posted by cojoman
after buying it, does it need to be programmed? What should i be worried about so that i don't screw up the new one i will get. I know how sensitive computers can be. Do you think i might still have some wiring issue? I havent seen the circuit so i don't really know how things are been powered.
Thanks
You will need no programing for this unit. You will need the plugs that plug into the module as I am sure yours may be too damaged to use. So your best bet is a used module with the plugs that were cut from the harness. You will need to splice these into the harness after cutting off the old plugs.
There is another module behind and above this one, this is the lift and tow alarm, it sounds when the rear of the car is raised to tow the car. this has to be switched of before towing. How does that one look? It should be OK as it is a little bit higher.
