Old May 18, 2014 | 11:01 AM
onehundred80
Default Re: Crossfire Wont start or turn over after flood
Originally Posted by cojoman
Can you please show the picture where i can find the lift and tow alarm? Does this module have any effect on making the car to start? I just want to hear the engine. I miss this car.
Also is there something else i should worry about before buying this module? What is the difference between central vacuum module and System security module? Am slightly confuse on both terms.
Thanks Guys. Am looking locally if i can find one i could go and pick up but if not then i will just order in ebay. Good thing there is no programming required . Good news is better than bad news
In post #13 it is seen under the bracket at the rear of the foam that holds the module, it is at the same height as the top of the foam box. I have one of these security/pump modules with the plugs but it is untested although it looks perfect.
