Old May 18, 2014 | 10:09 PM
  #41 (permalink)
RED DOG's Avatar
RED DOG
Default Re: Crossfire Wont start or turn over after flood
Originally Posted by cojoman
Okay i went and got the central locking pump module from my car. This is what it looks like currently. I really think this one is okay but the terminals are corroded and also the piece of metal holding it seems to be in very much corroded also but it doesn't seem to be as bad as the Vacuum Pump. I know this one might need to be programmed if i have to get a new one.
My questions is, can it be tested? At least before i go through the hassle of trying to get another one, i will love to see if it is still good.
What do you think?
Open up the case and post a photo of the circuit board inside. From the photos you posted I think it was underwater and is most likely ruined. This is not an expensive part so I wouldn't waste time trying to "save" it. Just get a replacement part.
If you have access to a sand blasting cabinet you can clean up the mounting bracket but again it's easier to get another one from where ever you end up getting the replacement module.
