Old May 20, 2014 | 11:04 PM
  #213 (permalink)
mobilefitt's Avatar
mobilefitt
Default Re: Crankshaft Position Sensor
Originally Posted by mobilefitt
Looks so easy, 35 min of re positioning the ratchet, the E8 and the extension.
Best thing to do is us a small E8 and a solid extension. Get the e8 and extension in place, then connect a small ratchet. Screw will come out with sensor once its loose.
Advanced Auto Part CPS for $47.50 works just fine! Life time warranty!
Wait. Cps is failing. Jiggled the wire and car starts but cuts off at higher rpm. I thought about something I read..... Pins are thinner on the advanced part. I m wondering if the pins aren't making good contact to the harness or if there is in fact a short in the connector.
