Old May 21, 2014 | 09:48 PM
syfi's Avatar
syfi
Default Re: want to install rear speakers in base crossfire
Originally Posted by astrnmrtom
I have a Blaupunkt MP66 Memphis head unit which is wired to the factory amp with an adapter plug. I'm using the rear RCA outputs to feed a small amp in the back to run the rear speakers. It makes a HUGE difference in the sound. Really fills in the soundstage. I started with a set of 3-1/2" Pioneers and recently replaced them with 5" MB Quart 2 ways. Sounds awesome - I'm sitting right in the middle of the music.
Tom
Hey Tom, I also have the MP66 wired the same. Is the small amp really needed or couldn't you just run the speakers directly off the RCA outs? Should be enough amp power from the MP66 for this small a speaker. Also, are you getting the use of the fader control with your setup?
