Old May 24, 2014 | 08:12 PM
  #685 (permalink)
racecar's Avatar
racecar
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
thanks for your reply.
I must've remembered it wrong that somebody said that the wheel wont lock after the repair.
So if it's not a part of the wheel lock , what is the thingy for?
And... I am 98% sure there was no spring when i removed the cover. and I was very careful, I couldn't have missed it. The unit looked factory fresh.
Strange. Anyway.. I am less concerned now, but still curious abt that shuttle&spring function.
thx
Jan
Originally Posted by whoosh
If you removed the spring and pin like the instructions, you are good to go. The wheel will still lock after the spring/pin is removed but your ignition key will not get stuck in the future.
