Old May 27, 2014 | 06:21 AM
Tommyj's Avatar
Tommyj
Default Re: Noise from the rear!
Originally Posted by xfchris
its probably the airline that goes from the pump in the boot floor to the door locks, listen around the tailgate hinge area there is a rubber boot that goes from the body to the tailgate and the airline goes through that and after a few years of the tailgate opening and shutting it can develop a leak...
https://www.crossfireforum.org/forum...w-i-fixed.html
Many thanks for the quick reply.
That sounds like the issue. I will have a look abit later. Hopefully I can locate it near the top and not needing to pull everything apart........im not that technically minded so hope it will be an easy enough fix.
Thanks again
