Old May 29, 2014 | 03:40 PM
onehundred80
Default Re: Intercooler Isolation Kit/Needswings
to purge out the air bubbles in the system.
Da55id, you got the instructions and are all set correct?
Let me be the first to congratulate you on being the Car Of the Month for June on Drag Times.
Please can you tell us where does the little hose from the IC pump go. The nipple is plugged on the new pumps. It appeared to be dry when I took it off the old pump so I assumed it was drain, but the hose just disappeared upward.
