Old Jun 6, 2014 | 09:32 PM
xme's Avatar
xme
Default Re: Recommend some rims?
Originally Posted by JEFASOLD
Don't give up yet, once you get things sorted, it will be a blast. Take a look at these and I think that there is one close to this, called GT7. available in 18s and 19s also 2 widths so the narrower one would suit you. Good for stock size but you could go wider if you wanted to. They are MRR brand.
+1, don't give up. The problem for wheels I like always seemed to be the rears... 19x8.5-9.5 +35 or less with the correct bore and bolt pattern doesn't seem to be terribly common. 18s and 20s were easy. I'm waiting on some backordered wheels myself still. It's been awhile. Ended up having to buy a cheap tire to replace a bubbled one and hold me over.
